spacefish69
Nov 19, 2022Aspirant
R7960P emailing logs
hello.. I use to get my logs emailed daily. then they stopped. I checked the settings all is same and good info. when I go to the log and click send log. it says email sent with the correct address bu...
Kitsap
Nov 19, 2022Master
spacefish69 wrote:
hello.. I use to get my logs emailed daily. then they stopped. I checked the settings all is same and good info. when I go to the log and click send log. it says email sent with the correct address but it is never recieved. any idea?
Per chance are you sending to a gmail.com address?
Did you check to see if the e-mail is landing in your spam/junk mail folder?
- spacefish69Nov 19, 2022Aspirantyes sending to Gmail. have also checked spam etc. have also tried sending to none Gmail.
I am and was using my internet company email smtp stuff and it was working great.- KitsapNov 19, 2022Master
I am and was using my internet company email smtp stuff and it was working great.When using Gmail, are you using the specially generated password for third party applications?
You are sure you have the outgoing mail server port number correct as well as the mail server authentication option set.
In your router log, it should show something similar to [email sent to: xxxxxx@gmail.com] Friday, November 18, 2022 05:00:04
- spacefish69Nov 19, 2022Aspirantin the log it says email sent... to the address I set (most of the time sometimes there is nothing about me sending the log)..
but nothing is recieved. I have even added a 2nd address for testing and nothing is recieved.
my smtp is not Gmail so using normal pw. I have double triple checked the smtp address and port numbers and verified the password.
