spacefish69
Nov 19, 2022Aspirant
R7960P emailing logs
hello.. I use to get my logs emailed daily. then they stopped. I checked the settings all is same and good info. when I go to the log and click send log. it says email sent with the correct address bu...
Kitsap
Nov 19, 2022Master
spacefish69 wrote:
hello.. I use to get my logs emailed daily. then they stopped. I checked the settings all is same and good info. when I go to the log and click send log. it says email sent with the correct address but it is never recieved. any idea?
Per chance are you sending to a gmail.com address?
Did you check to see if the e-mail is landing in your spam/junk mail folder?
spacefish69
yes sending to Gmail. have also checked spam etc. have also tried sending to none Gmail.
I am and was using my internet company email smtp stuff and it was working great.
- KitsapNov 19, 2022Master
I am and was using my internet company email smtp stuff and it was working great.When using Gmail, are you using the specially generated password for third party applications?
You are sure you have the outgoing mail server port number correct as well as the mail server authentication option set.
In your router log, it should show something similar to [email sent to: xxxxxx@gmail.com] Friday, November 18, 2022 05:00:04
- spacefish69Nov 19, 2022Aspirantin the log it says email sent... to the address I set (most of the time sometimes there is nothing about me sending the log)..
but nothing is recieved. I have even added a 2nd address for testing and nothing is recieved.
my smtp is not Gmail so using normal pw. I have double triple checked the smtp address and port numbers and verified the password.- KitsapNov 19, 2022Master
my smtp is not Gmail so using normal pw. I have double triple checked the smtp address and port numbers and verified the password.I am reaching for possibilities.
Are you using firmware version 1.4.4.94?
After the most recent firmware update, did you do a firmware default reset and reconfigure the router from scratch?
After you make changes to the configuration, do you power down (pull the power cord) and then reboot the router?
What brand name and model number is the modem/ONT in front of your router?
If it is a combination device with a router, has it been configured in bridge mode?
Are you using a web browser Ethernet connected to the router or the Nighthawk application to make the configuration changes?
