spacefish69
Nov 19, 2022Aspirant
R7960P emailing logs
hello.. I use to get my logs emailed daily. then they stopped. I checked the settings all is same and good info. when I go to the log and click send log. it says email sent with the correct address bu...
spacefish69
in the log it says email sent... to the address I set (most of the time sometimes there is nothing about me sending the log)..
but nothing is recieved. I have even added a 2nd address for testing and nothing is recieved.
my smtp is not Gmail so using normal pw. I have double triple checked the smtp address and port numbers and verified the password.
Kitsap
Nov 19, 2022Master
I am reaching for possibilities.
Are you using firmware version 1.4.4.94?
After the most recent firmware update, did you do a firmware default reset and reconfigure the router from scratch?
After you make changes to the configuration, do you power down (pull the power cord) and then reboot the router?
What brand name and model number is the modem/ONT in front of your router?
If it is a combination device with a router, has it been configured in bridge mode?
Are you using a web browser Ethernet connected to the router or the Nighthawk application to make the configuration changes?
