farmerda
Jan 06, 2023Follower
R7960P fails updating to 1.4.4.94_1.3.56
My router Nighthawk X6S AC3600 R7960P fails updating to 1.4.4.94_1.3.56 from 1.4.1.50_1.3.10 I have now tried downloading the file and thru the interface doing the update connected directly to the r...
Jan 07, 2023Guru - Experienced User
That firmware caused issues as it wouldn't upgrade.
If you're outside of warranty, you can try this guide:
If you still have a warranty, you can contact support and they should replace it.
