tano26
Mar 20, 2020Tutor
R7960P firmware not upgrading
I have attempted multiple times to upgrade my current firmware, V1.4.1.44_1.3.5, to V1.4.1.50_1.3.10 and it fails. I have tried letting the router update itself and also downloading upgrade zip file ...
antinode
Mar 20, 2020Guru
> I have attempted multiple times [...]
"attempted" _how_, exactly?
> [...] and it fails.
Any actual error messages?
> [...] downloading upgrade zip file straight from Netgear [site]. [...]
_Which_ "zip file"? "R7960P-V1.4.1.50_1.3.10.zip"? And then you did
what with it? Did you extract the firmware image file
("R7960P-V1.4.1.50_1.3.10.chk") from this "zip file"?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for
"Manually Upload Firmware to the Router".
> Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
And this has nothing to do with anything?
- Goliath60Mar 20, 2020Guide
Having same problem. I've allowed the auto update to download and upgrade firmware, goes through the motion and reboots router, but no change in firmware. Then downloaded the file and manually tried to update with same results. The logs are not showing any errors nor are there any messages showing an error. Just continues to have "A router firmware upgrade is available." at top of router admin page.
Going from
Firmware Version
V1.4.1.44_1.3.5 to1.4.1.50_1.3.10 Forgot to add that tidbit.
Thanks for any help.
- antinodeMar 20, 2020Guru
> Having same problem. [...]
And you seem to be having the same difficulty in supplying a useful
problem description.> [...] Then downloaded the file [...]
_Which_ "the file"?
> [...] and manually tried to update [...]
"tried" _how_ exactly?
> [...] with same results. [...]
The same as "it fails" is not an improvement over "it fails", which
is not a useful description.- Goliath60Mar 20, 2020Guide
Wow, making people feel little because thay asked a question is not helpful
" And you seem to be having the same difficulty in supplying a useful
problem description."Kind of crass, and out of line for someone asking for help. My opinion
_Which_ "the file"?
I guess the firemware update file, hence the subject heading (Thought it was self explanatory)
Again I thought this was self explanatory
is not a useful description.I presumed that failing was understood from the subject heading to mean it wasn't upgrading the firmware.
