tano26
Mar 20, 2020Tutor
R7960P firmware not upgrading
I have attempted multiple times to upgrade my current firmware, V1.4.1.44_1.3.5, to V1.4.1.50_1.3.10 and it fails. I have tried letting the router update itself and also downloading upgrade zip file ...
labatt
Mar 25, 2020Mentor
Zero_c00l wrote:Yeah I have the same problem. it tries to upgrade and after reboot it's still on the previous firmware (V1.4.1.44_1.3.5). You wouldthink Netgear test the upgrade file before publishing it, but I guess not!!!
You would hope the firmware was tested before posting. For the time I had a r8000 and r8000p I never got firmware that was bug free. In fact the same bugs existed firmware version after firmware version. Some say the firmware is farmed out to a 3rd party off shore. In any case there does not seem to be any testing or QA of the firmware before ship other then to see that it will load onto the router. There are bugs that are a year old and still are not fixed. I, personally, gave up on Netgear and went else where. More toward the commercial side. Lose things like parental controls when you do that, but I do not have any kids here to worry about.
Zero_c00l
Mar 25, 2020Star
