tano26
Mar 20, 2020Tutor
R7960P firmware not upgrading
I have attempted multiple times to upgrade my current firmware, V1.4.1.44_1.3.5, to V1.4.1.50_1.3.10 and it fails. I have tried letting the router update itself and also downloading upgrade zip file ...
andynbaker
Mar 29, 2020Guide
Mine is doing the same thing. Can't upgrade to the newest firware no matter what. I don't want to call support because I know what they are going to say: can you factory reset teh router?
ARRRGGGGHHHHH
Goliath60
Mar 29, 2020Guide
Yeah, that is what I'm going to do in the morning. Reset back to factory, try to update after that. I've lost my second 5ghz wifi channel, too. I'll let you know if it helps. If not, I'm taking back and getting a mesh system.
- Goliath60Mar 30, 2020Guide
Reset back to factory settings, still unable to upgrade firmware, tried both manually and used automated.
Also lost second WIFI 5 GHZ, that started several days ago.
I gave up and returned to Costco.
Went with the Orbi Mesh system (RBR50) and two satellites (RBS50), little pricier than I wanted but, we are moving to a 6000 foot house in a couple months and I figured it was what was best for our situation.
I almost didn't buy NetGear products again, but I've had good luck in the past and didn't want one bad experience to cloud judgement.
The setup was routine and simple, and seems to be working well. Hoping it goes better than the nighthawk did.
- Cycleman7960Sep 06, 2020Aspirant
Looks like a lot of people have had similar issues with this router that I am having. Purchased my R7960P Nighthawk X6S AC3600 Tri-Band WiFi Router from Costco in January of 2020. Router seems to be working fine. I received and email about a firmware update on August 13th. My router is running V1.4.1.50_1.3.10. The email says the new version is V1.4.1.62_1.3.22. When I check thru the web app it says there is no new firmware version available. I downloaded the firmware update file from the Netgear site and manually uploaded the file. Everything went fine. No errors. Router rebooted. But the firmware version did not change to the new version. Any ideas about how to fix this. I would think Netgear should be responsible for this if it is a bug in their router. Looking forward to hearing some feedback. Thanks in advance for your help.
- CKoppSep 07, 2020Luminary
You can try what worked for me and one other. Use a windows machine to download the V1.4.1.62_1.3.22 firmware to your windows desktop. Go to the advanced tab and select the router update option on left under Administration. When on this page in the web interface, browse to the firmware file you downloaded used the locate and select option. Once selected, use the upload function to update.
If all goes well you will see the upload bar graphic, and once this get to 100%, a message that the router is rebooting should appear. If all goes well from there when it reboots in a minute or two, you will be able to re log in and see that it is updated.
I first tried the check for update button - it did not work. Then tried the upload, but not from my desktop and it hung up on the upload.
Third time using the firmware file I downloaded onto my desktop, and all was well. Good Luck!
