tano26
Mar 20, 2020Tutor
R7960P firmware not upgrading
I have attempted multiple times to upgrade my current firmware, V1.4.1.44_1.3.5, to V1.4.1.50_1.3.10 and it fails. I have tried letting the router update itself and also downloading upgrade zip file ...
aveatr
Apr 11, 2020Guide
R7960 router
Same issue as other users. NETGEAR has released a faulty firmware update and is not addressing the problem.
They want me to buy additional software? Not until they respond to this issue!
I used the Netgear Firmware Update Assistant to try and upload the firmware from Netgear's server,
Current Firmware Version 1.4.1.44
New Firmware Version 1.4.1.50_1.3.10
It went through the motions of downloading and 'updating', rebooting the router, but without a change to the current version (Firmware Version V1.4.1.44_1.3.5)
This was tried 2 times without any change to firmware.
I then used the manual process to update through downloading zip file to a directory.
Going to NetGears site and downloading the R7960P-V1.4.1.50_1.3.10.zip, unzipped it and I used the R7960P-V1.4.1.50_1.3.10.chk file.
Using the manual process within the Routers Updater, I tried to update firmware again, again went through the motions and router rebooted.
This was tried twice without any changes in the firmware.
Went through logs Administration logs (with every option checked previously) and no errors concerning the update were found.
Hence my problem.
preed1
Apr 12, 2020Guide
I have the same problem. Firmware will not update.
- Wws1Apr 12, 2020GuideMy firmware will not update ; tried several times
- WheneverApr 12, 2020InitiateI’ve tried to upgrade three times already. Noticed seems like only GUI language version got .50 but firmware stays put. Also the web page still shows new firmware available.
Hardware Version R7960P
GUI Language Version V1.4.1.50_2.1.46.1
