tano26
Mar 20, 2020Tutor
R7960P firmware not upgrading
I have attempted multiple times to upgrade my current firmware, V1.4.1.44_1.3.5, to V1.4.1.50_1.3.10 and it fails. I have tried letting the router update itself and also downloading upgrade zip file ...
Zero_c00l
Apr 25, 2020Star
Funny that Ihave recieved this email from Netgear and the firmware update bug still exsists and users are not able to update their firmware!!!
DarrenM , any updates after your escalation?
Stinsonddog
Apr 26, 2020Star
Well glad I found this thread. Mine won't update the firmware but it does show the GUI updated.
| Hardware Version | R7960P |
| Firmware Version | V1.4.1.44_1.3.5 |
| GUI Language Version | V1.4.1.50_2.1.46.1 |
It asks if I want 1.4.1.50_1.3.10
I wonder if they will fix it ever?
Just an fyi I got that same email.
- RayinAlaskaJan 23, 2021Aspirant
Mine fails to upgrade the firmware, not matter what I do. It shows that the new firmware is available, but fails to download and upgrade. I have never had this type of problem with any router. I bought this router at CostCo last year. I will never purchase another router from NetGear, and am returning to LinkSys.
- michaelkenwardJan 24, 2021Guru - Experienced User
Never the best way to update firmware.
Here is now to get more control over the process.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
- Skhawar03Jan 24, 2021TutorI think this had been discussed as not working for the vast majority here including myself.
- Skhawar03Jan 24, 2021TutorWhy don't you call netgear support you must be under warranty of one year
Skhawar03 wrote:
Why don't you call netgear support you must be under warranty of one yearYou can't call. Any phone number you find with a web search is almost certainly a scam, but you can initiate the warranty process on line.
Start the RMA process by checking MyNetgear.
How do I request a Return Material Authorization (RMA)? | Answer | NETGEAR Support
