tano26
Mar 20, 2020Tutor
R7960P firmware not upgrading
I have attempted multiple times to upgrade my current firmware, V1.4.1.44_1.3.5, to V1.4.1.50_1.3.10 and it fails. I have tried letting the router update itself and also downloading upgrade zip file ...
DarrenM
Jun 29, 2020Sr. NETGEAR Moderator
We are working on a fix for this issue but a workaround is trying to load the new firmware via TFTP I linked how to do this below.
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
DarrenM
IdahoScott
Jun 29, 2020Apprentice
DarrenM
Darren,
I see the hot fix available on your support web site:
"https://www.netgear.com/support/download/"
Firmware Version 1.4.1.56 - Hot Fix
Is there a reason that this won't upload using the Netgear Admin "Router Update - Browse" function (using a wired connection, of course)?
Does this hot fix need to be applied ONLY via your Tftpd64 software? The release notes don't indicate that Tftpd64 is required, and Tftpd64 is a whole lot more complicated, with many steps for regular users to navigate. Tftpd64 seems like an unnecessary stumblinig block.
DarrenM
