tano26
Mar 20, 2020Tutor
R7960P firmware not upgrading
I have attempted multiple times to upgrade my current firmware, V1.4.1.44_1.3.5, to V1.4.1.50_1.3.10 and it fails. I have tried letting the router update itself and also downloading upgrade zip file ...
NickPasich
Jan 04, 2021Aspirant
I've done both the Check for new version from the Internet and Locate and select the upgrade file on your hard disk methods and they act like they're successful but I'm still stuck on V1.4.1.50_1.3.10 .... I've done a power-off for 5 minutes of no avail. Using ncftp, a "pwd" showed the location: ftp://updates1.netgear.com ... I tried "put R7960P-V1.4.1.66_1.3.26.chk" and got "server said: Permission denied." It appears that the partition doesn't have write permissions.
- antinodeJan 05, 2021Guru
> [...] Using ncftp, [...]
"Using" _how_, exactly? To do what, exactly?
> [...] a "pwd" showed the location: ftp://updates1.netgear.com ...
"FTP" and "TFTP" are spelled differently for a reason.
You seem to be trying to send a firmware file to a Netgear corporate
FTP server, _not_ to your own router, using FTP, _not_ TFTP. Wrong
destination, wrong protocol.> [...] I tried "put R7960P-V1.4.1.66_1.3.26.chk" and got "server said:
> permissions.Yes, Netgear probably doesn't want every confused person with an
Internet connection to be storing files on its FTP server(s). This does
not amaze me. You seem to be out of your depth.
In the words of the philosopher Williams, "If you don't think too
good, don't think too much."- walknbluezJan 06, 2021Tutor
Are you the resident snooty smart ass?
antinode wrote:> [...] Using ncftp, [...]
good, don't think too much."- antinodeJan 06, 2021Guru
> [...] smart ass?
As we said when _I_ was a child: Better smart than dumb.
- NickPasichJan 06, 2021Aspirant
Disregard my previous post ... It should read
- uxnguyenJan 07, 2021Guide
- NickPasichJan 07, 2021Aspirant
Yep... That's what mine is at.
uxnguyen wrote:Do you see the "GUI Language Version" got updated to 1.4.1.66.2.1.46.1?
