tano26
Mar 20, 2020Tutor
R7960P firmware not upgrading
I have attempted multiple times to upgrade my current firmware, V1.4.1.44_1.3.5, to V1.4.1.50_1.3.10 and it fails. I have tried letting the router update itself and also downloading upgrade zip file ...
NickPasich
Jan 04, 2021Aspirant
I've done both the Check for new version from the Internet and Locate and select the upgrade file on your hard disk methods and they act like they're successful but I'm still stuck on V1.4.1.50_1.3.10 .... I've done a power-off for 5 minutes of no avail. Using ncftp, a "pwd" showed the location: ftp://updates1.netgear.com ... I tried "put R7960P-V1.4.1.66_1.3.26.chk" and got "server said: Permission denied." It appears that the partition doesn't have write permissions.
NickPasich
Jan 06, 2021Aspirant
Disregard my previous post ... It should read
- uxnguyenJan 07, 2021Guide
- NickPasichJan 07, 2021Aspirant
Yep... That's what mine is at.
uxnguyen wrote:Do you see the "GUI Language Version" got updated to 1.4.1.66.2.1.46.1?
- uxnguyenJan 08, 2021Guide
Thanks Nick! we have the same issue...
