tano26
Mar 20, 2020Tutor
R7960P firmware not upgrading
I have attempted multiple times to upgrade my current firmware, V1.4.1.44_1.3.5, to V1.4.1.50_1.3.10 and it fails. I have tried letting the router update itself and also downloading upgrade zip file ...
NickPasich
Jan 06, 2021Aspirant
Disregard my previous post ... It should read
I've done both the Check for new version from the Internet and Locate and select the upgrade file on your hard disk methods and they act like they're successful but I'm still stuck on V1.4.1.50_1.3.10 .... I've done a power-off for 5 minutes of no avail.
uxnguyen
Jan 07, 2021Guide
- NickPasichJan 07, 2021Aspirant
Yep... That's what mine is at.
uxnguyen wrote:Do you see the "GUI Language Version" got updated to 1.4.1.66.2.1.46.1?
- uxnguyenJan 08, 2021Guide
Thanks Nick! we have the same issue...
- NickPasichJan 08, 2021Aspirant
Just downloaded and tried updating to the newest version
Download Link : https://www.downloads.netgear.com/files/GDC/R7960P/R7960P-V1.4.1.68_1.3.28.zip
Both methods tried: "Firmware Update Assistant" and "Locate and select the upgrade on your hard disk".
Same thing .... Still stuck on Version 1.4.1.50_1.3.10
