tano26
Mar 20, 2020Tutor
R7960P firmware not upgrading
I have attempted multiple times to upgrade my current firmware, V1.4.1.44_1.3.5, to V1.4.1.50_1.3.10 and it fails. I have tried letting the router update itself and also downloading upgrade zip file ...
michaelkenward
Apr 27, 2021Guru - Experienced User
Sgt_Flash wrote:
I have been trying for over a month to update the firmware ...
How?
Manual update? Started by an app? Started by the router?
Sgt_Flash
Apr 27, 2021Aspirant
I have all three ways you mentioned several times over the last month or two and all my router does if reboot. I have tried using the app on my Samsung Galaxy S20+, I tried from my laptop via WiFi and ethernet, I have tried using my PC connected via ethernet directly to the R960P router. I have tried the app, manual, and by the router. I cannot get it to take. My show the unloading a spinning clock(?). It gets about half way and reboots. After it reboots it still shows the old firmware.
My router currently has firmware v 1.4.1.50. There is currently versions 1.4.1.64, 66 and 68 available. I have tried them all.
- MrfatboyApr 27, 2021StarMine didn’t update until I put the firmware file on the desktop and used the router GUI to select it and upgrade it.
- michaelkenwardApr 27, 2021Guru - Experienced User
Mrfatboy wrote:
Mine didn’t update until I put the firmware file on the desktop and used the router GUI to select it and upgrade it.That'll be this one:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
- MrfatboyApr 27, 2021StarBasically yes. However it was key that the file be on the desktop. Every time I tried it from a sub folder or on another drive it wouldn’t work.
- StinsonddogApr 27, 2021Star
Mrfatboy if this works for all these Costco routers that would be great but as I recall it didn't work for many. Hope it does now.
- MrfatboyApr 27, 2021StarMy fathers router is on 44. I’m a little afraid to try to upgrade his because I have to do it remotely through TeamViewer. If it doesn’t come back it would be very bad. 😳
If I do decide to try am going to attempt 68 directly while bypassing the others If I’m successful I will let everybody know.
