tano26
Mar 20, 2020Tutor
R7960P firmware not upgrading
I have attempted multiple times to upgrade my current firmware, V1.4.1.44_1.3.5, to V1.4.1.50_1.3.10 and it fails. I have tried letting the router update itself and also downloading upgrade zip file ...
Sgt_Flash
Apr 27, 2021Aspirant
I have all three ways you mentioned several times over the last month or two and all my router does if reboot. I have tried using the app on my Samsung Galaxy S20+, I tried from my laptop via WiFi and ethernet, I have tried using my PC connected via ethernet directly to the R960P router. I have tried the app, manual, and by the router. I cannot get it to take. My show the unloading a spinning clock(?). It gets about half way and reboots. After it reboots it still shows the old firmware.
My router currently has firmware v 1.4.1.50. There is currently versions 1.4.1.64, 66 and 68 available. I have tried them all.
Mrfatboy
Apr 27, 2021Star
Mine didn’t update until I put the firmware file on the desktop and used the router GUI to select it and upgrade it.
- michaelkenwardApr 27, 2021Guru - Experienced User
Mrfatboy wrote:
Mine didn’t update until I put the firmware file on the desktop and used the router GUI to select it and upgrade it.That'll be this one:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
- MrfatboyApr 27, 2021StarBasically yes. However it was key that the file be on the desktop. Every time I tried it from a sub folder or on another drive it wouldn’t work.
Mrfatboy wrote:
Basically yes. However it was key that the file be on the desktop. Every time I tried it from a sub folder or on another drive it wouldn’t work.Wow. Never seen that before. Weird. Very useful tip too.
- StinsonddogApr 27, 2021Star
Mrfatboy if this works for all these Costco routers that would be great but as I recall it didn't work for many. Hope it does now.
- MrfatboyApr 27, 2021StarMy fathers router is on 44. I’m a little afraid to try to upgrade his because I have to do it remotely through TeamViewer. If it doesn’t come back it would be very bad. 😳
If I do decide to try am going to attempt 68 directly while bypassing the others If I’m successful I will let everybody know. - CKoppApr 27, 2021Apprentice
My experience was similar to Mrfratboy. Only able to move off .50 version when the file was on the desktop. Next update (.66) required a reboot after it finished and a reboot of my PC to recognize the router. .68 upgrade was done via Web browser, worked great.
Good luck!
- michaelkenwardApr 28, 2021Guru - Experienced User
Many thanks for that report. Very useful.
Does this mean that we are getting somewhere with a definitive solution to the problem, a year after it first cropped up here?
Enough positive reports and perhaps it can be marked Accept as Solution.
