tano26
Mar 20, 2020Tutor
R7960P firmware not upgrading
I have attempted multiple times to upgrade my current firmware, V1.4.1.44_1.3.5, to V1.4.1.50_1.3.10 and it fails. I have tried letting the router update itself and also downloading upgrade zip file ...
Pcjunkman1978
May 05, 2021Aspirant
My R7960p is doing the same thing it wont update the firmware! it's stuck on version
V1.4.1.50_1.3.10
Sgt_Flash
May 06, 2021Aspirant
Pcjunkman1978 wrote:My R7960p is doing the same thing it wont update the firmware! it's stuck on version
V1.4.1.50_1.3.10
The same here
- RayinAlaskaMay 07, 2021Aspirant
The problem with my router was solved by upgrading the firmaware manually. Don't let the router upgrade itself automatically.
- Sgt_FlashMay 07, 2021Aspirant
RayinAlaska wrote:The problem with my router was solved by upgrading the firmaware manually. Don't let the router upgrade itself automatically.
I tried many times over the last couple of months. "NOTHING" works 4 me. I tired from the folder I downloaded to, I tried from the desktop. I tried using my smartphone via the Nighthawk app, I tried using my laptop. I tried connecting via wireless and and ethernet. It will not upload.
- tano26May 08, 2021Tutor
Same issue. Nothing has upgraded my frimware for over a year.
