BigItch
Apr 22, 2022Aspirant
R7960P locks up when you try Disable auto firmware updates
I've been fighting the Firmware DNS issues for months now, but have routinely backed up to an older firmware version that does not have the issues . . . now, the AutoUpdate feature uploads and instal...
Apr 22, 2022Guru - Experienced User
What browser are you using?
- BigItchApr 22, 2022Aspirant
I'm using the newest version of Chrome . . .Version 100.0.4896.127 (Official Build) (64-bit)
The version that I back up to is v1.4.1.68_1.3.28 because that's the last one I have that doesn't exhibit the DNS issues.
The version that auto-updates is v1.4.3.88_1.3.50
- FURRYe38Apr 22, 2022Guru - Experienced User
Does it happen in other browsers as well?
I have mine online now however I haven't tried to disable auto updates yet. I use MS Edge to set it up the other day.
One can enable IPv6 as a work around for DNS issue. I believe I saw some DNS issues yesterday however I'm giving it a bit more time on v.88
I'll try Edge after I get to the office and reset the router . . .can't connect to it after this lockup after "Save"
Thanks for your help . . . if you're able to "Disable" with no issues, let me know . . .thanks again
