ratler
Aug 29, 2021Aspirant
R7960P ReadyShare
I want to setup ReadyShare on my Nighthawk R7960P router. I have a USB stick plugged in but that doesn't seem to work. Does the device have to be a USB disk drive? If so can it be EITHER a mechani...
michaelkenward
Aug 30, 2021Guru - Experienced User
ratler wrote:
I want to setup ReadyShare on my Nighthawk R7960P router. I have a USB stick plugged in but that doesn't seem to work. Does the device have to be a USB disk drive? If so can it be EITHER a mechanical drive (heads, platters, all that) OR can it be a HDD?
It can be many tnings, but you don't tell us what you are using, so who knows?
The manual spells out some of the requirements.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual USB Device Requirements.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
You can get an idea of what you can use from this page:
Will my USB drive work with ReadySHARE | Answer | NETGEAR Support
For serious networking use Ethernet.
ratler
Aug 30, 2021Aspirant
Well, actually I said I was using a USB stick so you do know something..... And it does NOT require any software to be downloaded to use it. But it's a SanDisk USB 3.0 Ultra Fit flash drive.
But thanks for the response with the link about disk drives.
