aktanker
Apr 02, 2021Initiate
R7960p Router will not update firmware
Hello, Attempting to up date router firmware from 1.4.1.50 to 1.4.1.68_1.3.28. Each attempt has failed --rebooted modem and router. Attempting update via iphone Nighthawk app. After several attempts...
- Jul 13, 2022
Was able to update my router that was stuck on R7960P-V1.4.1.50_1.3.10.
Used the nmrpflash method. Updated to R7960P V1.4.1.64_1.3.25 then used the Netgear router software to update to R7960P-V1.4.3.88_1.3.50.
Method is here:
https://github.com/jclehner/nmrpflash
I put the firmware file in the same folder as the nmrpflash.exe file.
Was using my router as an endpoint, initially had failures until I noticed after the attempts my attached computer ip address was changed from 192.168.2.5 to 192.254.177.93, since my router was set up as an endpoint and assigning. Checked by running the nmrpflash "-L" command to check the connection name <net9> and ip <192.254.177.93>.
used the -a and -A commands to assign the ip address on my computer and target router. -A 192.254.177.93 and -a 192.254.177.94
ran the nmrpflash.exe with the the following command line and it worked.
nmrpflash -A 192.254.177.93 -a 192.254.177.94 -i net9 -f R7960P-V1.4.1.64_1.3.25.chk
Sep 09, 2021Guru - Experienced User
For the R7960P, there hasn't been any intermeddiate FW builds. One can go from a low version right into something higher.
I believe I had .v44 on mine and when to 68. I see there is a hot fix.
Also abbysgrandpa1 sometimes the router auto udpate doesn't include newer versions of FW. NG may not assigned these to be auto updated so these won't be auto updated. So users can check the NG download page for whats available to manual download and installation. You always can manually update the router your self. Or Not.
https://www.netgear.com/support/product/R7960P.aspx#download
abbysgrandpa1
Sep 09, 2021Guide
thank you kindly and sorry i am out of synch in my replies, i just noticed this reply of yours after i posted my reply to earlier thread. per that post, yes i did download and manually applies the updates and still not updating sadly. thank you kindly in advance much appreciated the insights and help.
- FURRYe38Sep 09, 2021Guru - Experienced User
What browser are you using to apply the FW udpates?
Be sure you are clearing all browser caches before and after sending the FW file to the router.
I presume you are unpacking the .zip file before hand?
- abbysgrandpa1Sep 09, 2021Guide
thank you. yes i unpack the zip file (to the local hard disk) which results in 2 files, one with a "dot chk" at the end and the other seems like a simple instructions file as a html. and it is this "dot chk" file that i "point to"/"upload" in the manual upgrade process. As for browser, i am using Chrome. also tried with Safari and firefox browsers just now and unfortunately no luck. yes, explicitly went in and cleared "cached images and files" options for all (thanks for the suggestion) and still no-go. It still goes through the full set of steps of "updating"; with no error messages nor any pop-ups; reboots; logs-me-out; i log back in; and still displays the old firmware version.
thank you again.
Ok, try this, disconnect the router from the ISP modem. Just have the one wired PC conencted.
Factory reset the router by pressing the reset button in back for 10 seconds then release.
Use FF and go to 192.168.1.1. You should seen a use NH app web page to setup the router. Scroll down and select the bottom link, that you don't have the app. Select I'll setup the router manually. Get thru the setup wizard.
Go in and try the FW update again sending the .chk file down. After the file is send and you see the router auto reboot. Exit and close the browser. After the router seems back online, check the log in page at 192.168.1.1 and log in and see the version...
Hello and thank you again for suggestions.Ok, had to wait for family to finish zoom, etc so i could do this. Just completed the tasks per your suggestions. 1) unplugged router from Internet. 2) just had 1 laptop (that has the "dot chk" file unzipped on its local drive) hard-wired (ethernet) plugged directly into the router. 3) manually hard-reset router via the little-button on device. 4) selected "manual setup" option at bottom of screen. 5) did the manual firmware update with the aforementioned "dot chk" file from the local hard drive. 6) (crossed-my-fingers-and-mentally-called-upon-the-router-gods-and-goddesses-to-bestow-magic-on-my-router). 7) No errors nor popups or anything at all - similar experience of "all seems fine with update". 8) Exited and closed browser. 9) re-launched it to the routerlogin dot net and signed back in --> and sadly, no dice. same version number still: v1.4.1.44_1.3.5 -- sigh.
i hope there's some magical remedy/fix. And once again i am deeply grateful for all the insights, help and direction - most kind of you all. thank you.
- FURRYe38Sep 10, 2021Guru - Experienced User
And just checking you downloaded a more recent version of FW file for the R7960? What version are you attempting to install?
- abbysgrandpa1Sep 10, 2021Guide
correct yes. most recent (at least as of yesterday when i double checked the netgear download site before initiating those steps). the version i have downloaded and was attempting to update firmware with: V1.4.1.68_1.3.28
PS: i also tried the V1.4.1.82_1.3.40-HotFix that <michaelkenward> suggested earlier in response to my query a day or so ago - ( grateful for that suggestion and help as well ) and unfortunately, similar experience of update process "seemingly conveying all fine" with no errors/popups but still not updating the firmware :(
- FURRYe38Sep 13, 2021Guru - Experienced User
Ok, I just updated my R7960P thats in wireless bridge mode and it took using the v82 hot fix.
I presume that yours maybe faulty or in some bad state and not able to take a FW update. I'd return the router to place of purchase and get another one.
