aktanker
Apr 02, 2021Initiate
R7960p Router will not update firmware
Hello, Attempting to up date router firmware from 1.4.1.50 to 1.4.1.68_1.3.28. Each attempt has failed --rebooted modem and router. Attempting update via iphone Nighthawk app. After several attempts...
- Jul 13, 2022
Was able to update my router that was stuck on R7960P-V1.4.1.50_1.3.10.
Used the nmrpflash method. Updated to R7960P V1.4.1.64_1.3.25 then used the Netgear router software to update to R7960P-V1.4.3.88_1.3.50.
Method is here:
https://github.com/jclehner/nmrpflash
I put the firmware file in the same folder as the nmrpflash.exe file.
Was using my router as an endpoint, initially had failures until I noticed after the attempts my attached computer ip address was changed from 192.168.2.5 to 192.254.177.93, since my router was set up as an endpoint and assigning. Checked by running the nmrpflash "-L" command to check the connection name <net9> and ip <192.254.177.93>.
used the -a and -A commands to assign the ip address on my computer and target router. -A 192.254.177.93 and -a 192.254.177.94
ran the nmrpflash.exe with the the following command line and it worked.
nmrpflash -A 192.254.177.93 -a 192.254.177.94 -i net9 -f R7960P-V1.4.1.64_1.3.25.chk
sdwelling
Sep 22, 2021Initiate
Spent hours on this today and I've pretty much given up. Both methods described fail repeatedly, with no errors thrown. Logs indicate no new firmware installed and don't show any errors. Other forums indicate that a hard reset does not work either. I was going to go direct from the command line in either windows or Linux, but that's going further than one should be expected to go. ππ
Tinslep
Dec 28, 2021Star
I am late to the party on this. I bought the R7960P a couple of years ago from Costco and then gave it to a friend to use over a year ago. I get software update notifications from Netgear and usually check the update status when I visit.
This Fall I got a notification and noticed it did not automatically update so I tried to kick it off manually with no success. I though it might be an issue with her older computer so tried with mine and also with the Nighthawk App with no success.
This crazyness of failing upgrades is unacceptable for non-techie folks who rely on Netgear products to just work. Unfortunately this will have me looking to other manufacturers for future upgrades of my network and will recommend friends do the same.
- FURRYe38Dec 28, 2021Guru - Experienced User
Something to contact NG support about. Let them know what your seeing. I was able to update mine, however mine was in Bridge mode when it updated. Not sure if this is something that might help.
- TurbodogToddJul 13, 2022Guide
Method is here:
- FURRYe38Jul 13, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. π‘ - TurbodogToddJul 13, 2022Guide
Good comment on saving a config file. I makes it easier, used my backup configuration file after flashing the router to load my settings.
- TinslepJul 13, 2022StarI am glad you found a solution but this doesnβt help non-technical people who bought their router at Costco and expect it to update automatically.
That was me, bought it at Costco and expected it to update automatically, or at least update through the app and web interfaces. Lived with it for several years, without updating, then spent the time, found a few links and followed the directions to update. If still under warranty then certainly people should return to Costco.
I recommend if you know of a friend, family member or neighbor that could help out. See if they can help you get the router updated.
Tinslep wrote:
I am glad you found a solution but this doesnβt help non-technical people who bought their router at Costco and expect it to update automatically. - TinslepJul 13, 2022Star
I was able to update mine eventually, but I still say, for the thousands that bought it at Costco and couldn't, they probably went out and bought another (non Netgear) router. I know my friend did.
Yes you could try for a return, but it isn't a Costco issue, it is a Netgear issue.
You buy a router and register it with Netgear. You get E-mail notifications of updates. They work fine for over a year. Then they stop and Netgear will not respond to issues.
Just leaves a bad taste for future customers.
I agree with all of that, my main router is a different brand, this issue originally caused me to use this router as an endpoint only.
Glad you were able to update yours. My original comment was to maybe help anyone in the same situation.
