SHRNKS
Apr 14, 2024Aspirant
R7960P unable to update frimware
Bought a second hand Nighthawk X6S. I was able to setup and connect it to my modem (C7000v2) no problem, but it will not accept firmware updates. I have tried it through the app, going through my pc ...
michaelkenward
Apr 15, 2024Guru - Experienced User
You are adding a router to a modem/router. Bad idea.
Two routers on your network can cause headaches. For example, you can end up with local problems with address on your network. Among other things, the other router can misdirect traffic to addresses that the Netgear router usually handles, such as routerlogin.net or the usual default IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point (AP) with a wired connection to the main router. Netgear advises this, as does just about every site you will visit.
My NETGEAR or Orbi router is connected to an ISP gateway or another router, and it's causing double NAT problems. How do I fix them? - NETGEAR Support
For your C7000v2 read this bit of the manual:
Connect Your Modem Router to a Router After Installation and Activation
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Sometimes it is easier to put the second router into AP mode.
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
- SHRNKSMay 03, 2024Aspirant
Hey, you are correct that I did use my modem as a network, but once the router was purchased I turned off wireless for the modem and it is only used as a modem from this point. Now I know that modem router combo isn't useful long-term, but its only a little over a year old and don't think it could be a part of the issue; unless there's info I am missing that other users have experienced dealing with updates to their router. please correct me if I'm wrong of course! Thank you for your comment!
- michaelkenwardMay 04, 2024Guru - Experienced User
Turning off the wifi does not disable the router part of a modem/router.
See the section on the manual for the C7000v2
Installation and ActivationRemember, when playing around with devices, you may have to restart the network to get all of the devices on it to configure themselves correctly.
Be sure to restart your network in this sequence:- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
What message do you get when you try ti upload the firmware?
Then there is this:
Search - NETGEAR Communities – R7960P firmware
