SHRNKS
Apr 14, 2024Aspirant
R7960P unable to update frimware
Bought a second hand Nighthawk X6S. I was able to setup and connect it to my modem (C7000v2) no problem, but it will not accept firmware updates. I have tried it through the app, going through my pc ...
SHRNKS
May 03, 2024Aspirant
Hey, you are correct that I did use my modem as a network, but once the router was purchased I turned off wireless for the modem and it is only used as a modem from this point. Now I know that modem router combo isn't useful long-term, but its only a little over a year old and don't think it could be a part of the issue; unless there's info I am missing that other users have experienced dealing with updates to their router. please correct me if I'm wrong of course! Thank you for your comment!
michaelkenward
May 04, 2024Guru - Experienced User
Turning off the wifi does not disable the router part of a modem/router.
See the section on the manual for the C7000v2
Connect Your Modem Router to a Router After
Installation and Activation
Remember, when playing around with devices, you may have to restart the network to get all of the devices on it to configure themselves correctly.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
What message do you get when you try ti upload the firmware?
Then there is this:
Search - NETGEAR Communities – R7960P firmware
