Pebkac
Jul 28, 2021Aspirant
R7960P upgrade from 1.4.1.50_1.3.10 does not work
My Nightwawk R7960P router display "upgrade available" message, but when I try to upgrade, nothing happens, the version stays at 1.4.1.50_1.3.10. So far I tried: 1. UI upgrade - it goes through ...
Pebkac
Aug 18, 2021Aspirant
Update for those who may find this in search:
Talked to the Netgear support, they basically said "oh, we need to replace it", then since it was older than a year (bought it 1.5 years ago) they said "oh, too late, go away, you're on your own". So looks like it's a defective product which has no fix and Netgear has no solution for it and no intent to stand behind it. You have yourself to blame for being so easy a mark. Let it be my lesson for the future.
