Vandrakus
Jan 22, 2022Aspirant
R800 connection problems.
I have been experiencing connectivity problems with my router since purchase but have been able to put up with small problems up until now. I have another topic that I started about why I was getting...
Jan 23, 2022Guru - Experienced User
You went to a version 21 version behind.
Why not just go back one or 2 versions?
Try updating to the 1.0.4.68 version. After the update, do a factory reset/reinstall. Make sure to leave access control, traffic monitoring, parental controls, and qos all disabled.
