themofoman
Apr 07, 2024Aspirant
R800 Plex Remote Access not available outside of network
Hello, I'm having issues with my Plex server on my Nighthawk X6 R8000. It was setup and located in another place and had remote access. But when I brought it home and connected it to my Nighthawk X...
Apr 07, 2024Guru - Experienced User
1. you mean the R9000?
2. you have it connected to the r8000? Is the r9000 in access point mode then?
3. what gateway is connected to the r8000
themofoman
Thanks for the reply. I don't have a R9000, I have the R8000. It is connected to an access point but I don't think that's a problem.
- plemansApr 07, 2024Guru - Experienced User
The r8000 doesn't have a built in plex server.
So what's running as your plex server?
What is it connected to?
what modem/gateway is the r8000 connected to?
Troubleshooting Remote Access | Plex Support
- themofomanApr 07, 2024Aspirant
Sorry, I have a server that I'm running Plex server on with the OS Ubuntu. And it's plugged into a switch (not access point) that's connected to the R8000. It was pulled into a switch where it was configured before I brought it home and had remote access . When I brought it home the remote access is not available port 32400. Thanks for having patience with me.
what modem/gateway is the router connected to?
did you try the troubleshooting from plex? That's going to be key is finding out what steps you need for remote access
