Garrbw
Feb 16, 2022Tutor
R8000 — Nighthawk X6 AC3200 Tri Band WiFi Gigabit Router Drops internet
With all the people having issues dropping the internet from firmware update. Is Netgear working on a solution to this problem? What can be done to correct this issue?
Feb 16, 2022Guru - Experienced User
I know they're aware of the issue but they don't release info on plans for firmware updates or whats going on with it.
Some people had good luck with the latest version with ipv6 enabled.
did you try that?
Garrbw
Feb 16, 2022Tutor
I do have the latest update, but I don't understand how to select ipv6 enabled. I am uneducated when it comes to routers.
- plemansFeb 16, 2022Guru - Experienced User
- GarrbwFeb 16, 2022Tutor
Thanks I'll check it out and let you know!
Good luck, if it doesn't help, you can downgrade the firmware a version. It just seems like the latest had the issue. But again, a lot of people had luck with using ipv6. A few were able to do a factory reset and it worked fine.
