Airpainters
Oct 25, 2021Tutor
R8000 — Nighthawk X6 AC3200 Tri Band WiFi Gigabit Router
After the last 2 firmware updates, experiencing problems with wifi and cabled connections dropping repeatedly for Windows 10 notebooks, android phones, the internet connection is via an LTE radio (ru...
- Oct 26, 2021
I'd try downgrading to the versionthat did work fine. there's been some DNS issues on the newer firmware releases across several models.
Oct 25, 2021Guru - Experienced User
what lte gateway is it connected to?
It just started after a firmware update?
What firmware version are you on?
- AirpaintersOct 25, 2021Tutor
current firmware:
Firmware Version
V1.0.4.76_10.1.82
the problem started after the update before that, thought the latest one would fix it, but did not.connected to NWIC, Niagara Wireless Internet NWIC | Niagara's High-Speed Internet Provider | Rural Wireless & Cable
- plemansOct 26, 2021Guru - Experienced User
- AirpaintersOct 26, 2021Tutor
I went back to Firmware Version
V1.0.4.68_10.1.75Time will tell
