Airpainters's avatar
Oct 25, 2021
R8000 — Nighthawk X6 AC3200 Tri Band WiFi Gigabit Router
After the last 2 firmware updates, experiencing problems with wifi and cabled connections dropping repeatedly for Windows 10 notebooks, android phones, the internet connection is via an LTE radio (ru...
  • plemans's avatar
    Oct 26, 2021
    I'd try downgrading to the versionthat did work fine. there's been some DNS issues on the newer firmware releases across several models.
