jbrandibas
Feb 07, 2016Aspirant
R8000 - Cannot administer router via wired connection
I have logged a support ticket, but I figured I would throw my question out here as well. I just got a new R8000 today and went to set it up, but I can't seem to administer the router through the...
- Feb 15, 2016
Hi jbrandibas,
Please try the steps on the KB article below.
jbrandibas
Feb 14, 2016Aspirant
Still not working but I am almost 100% certain it is my antivirus firewall. Oddly enough if I turn off protection, it still won't let me access it. I use Kaspersky, and a few people have said that they wound up un-installing it and it would let them access the router page. That seems a bit excessive to me, I would rather fine out why the firewall is blocking it.
jbrandibas
Thsi is what I get in the browser:
This webpage is not available
ERR_CONNECTION_RESET
The connection to 192.168.1.1 was interrupted.
Check your Internet connection
Check any cables and reboot any routers, modems, or other network devices you may be using.
Allow Chrome to access the network in your firewall or antivirus settings.
If it is already listed as a program allowed to access the network, try removing it from the list and adding it again.
If you use a proxy server...
Check your proxy settings or contact your network administrator to make sure the proxy server is working. If you don't believe you should be using a proxy server: Go to the Chrome menu > Settings > Show advanced settings... > Change proxy settings... > LAN Settings and deselect "Use a proxy server for your LAN".
- jbrandibasFeb 14, 2016Aspirant
Well, I finally gave in and uninstalled Kaspersky. That fixed it, so I can access the admin page now, but I don't ahve a virus scanner. Anyone know what it could be that it is blocking?
- JamesGLFeb 15, 2016NETGEAR Employee Retired
Hi jbrandibas,
- jbrandibasFeb 18, 2016Aspirant
This worked, thanks so much.
- storm1985Feb 16, 2016Prodigy
jbrandibas Once you can access the UI you can reinstall the Antivirus software and UI will still be accessible.
