Yanlisman
Feb 07, 2021Guide
R8000 - connectivity issues
Hi Team X6 R8000 router 4MKC997AA02AC Firmware V1.0.4.68_10.1.75 Internet speed test "Good", phone app shows111.33 down, 9.8 up Panel lights: Power: Solid white Internet: flashing white 2.4: ...
- Feb 07, 2021
from the downgraded version. Once downgraded, then do the factory reset/reinstall. Reason why is old settings can cause issues when switching between firmwares.
Yanlisman
Feb 07, 2021Guide
OK, firmware rolled back as your earlier reply. Quite straight forward when you delve into the admin options.
Now running V1.0.4.28_10.1.54
When you say reset and clean install, do you mean of this firmware or the latest firmware?
Rob
Feb 07, 2021Guru - Experienced User
