jeepeecreepee's avatar
Dec 20, 2021
R8000 - Disabling Remote Management
Hey guys, trying to get some help. I have a R8000 router. I am trying to disable any kind of remote management, or management done to the router by any devices connected to the network wirelessly.
First Attempt:
So I tried going into the router admin page, 192.168.1.1. I go under advanced > select security > advanced management. But all it shows me is to "Always use HTTPS to access router"
2nd Attempt:
I opened the Guest Access point. I enabled Broadcast of SSID, and Enabled the Guest network, but I leave the box "Allow guests to see each other and access my local network" Unchecked. Now I tried to test it, by logging in through one of my devices, as soon as I type 192.168.1.1, it just prompts me like normal, and I can still access the router just like normal.
Even though under Netgear help it still says "When unchecked, users connecting to this guest network can only access the Internet and cannot access any other devices in the same network or in other networks, including the main network and the wired network. In addition, all the clients in this guest network cannot access router's management GUI or any other services provided by the router (for example, ReadySHARE Storage, ReadySHARE Printer... if the router supports these functions)."
So is this a glitch in Netgears security? I mean if the company really wanted to be most secure, wouldnt they give you the option to allow only ethernet management, rather than online based management?
Does anyone have a sure workaround, where I can disable any modification to the router by a device connected wirelessly? Thanks
  • FURRYe38's avatar
    Use the Nighthawk app and you can disable "Anywhere Access".
    Router Web page managment is no longer seen on the routers web page. NG seems to be moving to the NH app.
    • jeepeecreepee's avatar
      jeepeecreepee
      No difference. I disabled the Anywhere access through the NH App, still I am able to access 192.168.1.1 through devices on the network. Any other potential ideas? Any way we can let Netgear know of this directly? I even rebooted the router to make sure the update took effect.
      My guests can access local network drives, AND router settings, wows
      • FURRYe38's avatar
        You can't disable LAN side access to the routers web page. Thats always enabled. Thats normal as well.
        Remote Management which is now Anywhere Access on the NH app is for allowing access to the router from remote locations from the WAN side only.
