Katman09
May 18, 2024Aspirant
R8000 - Error logging into Mozilla - 404 Fil eor directory not found
I have an AC3200 Tri-Band WiFi router (Nighthawk x6). I used to be able to login to Mozilla to access my dashboard but i receive an error now. I can log in using Edge or Chrome but wondering why i ...
michaelkenward
May 19, 2024Guru - Experienced User
Katman09 wrote:
I can log in using Edge or Chrome but wondering why i can't use Mozilla.
Probably because they changed something in Mozilla.
Your router doesn't look around and say "Here comes Mozilla. Batten down the hatches."
As browsers get more and more security conscious they put on more layers of protection. If anything, I find that Firefox causes less trouble on that front.
Have you looked at the security warnings?
