Katman09
May 18, 2024Aspirant
R8000 - Error logging into Mozilla - 404 Fil eor directory not found
I have an AC3200 Tri-Band WiFi router (Nighthawk x6). I used to be able to login to Mozilla to access my dashboard but i receive an error now. I can log in using Edge or Chrome but wondering why i ...
MarkK11
May 19, 2024Aspirant
Katman09 wrote: Manage Publix passportI have an AC3200 Tri-Band WiFi router (Nighthawk x6). I used to be able to login to Mozilla to access my dashboard but i receive an error now. I can log in using Edge or Chrome but wondering why i can't use Mozilla. Anyone have any suggestions? I was at first concerned someone got into my network. Thank you!
Frank
The issue with Mozilla might be due to a browser-specific problem such as cache or extensions. Try clearing your Mozilla browser cache and disabling any add-ons. If the problem persists, consider resetting Mozilla to its default settings. Rest assured, it’s unlikely that this issue indicates a security breach in your network.
