philip_m
Aug 12, 2021Initiate
R8000 - Have to load every page 2x after installing V1.0.4.74_10.1.80
I updated my R8000/X6 to V1.0.4.74_10.1.80 yesterday. Now when i go to many websites (e.g this one) I first i get 'site not found' then i refresh the page (F5) and it loads. I tried firefox, Chrom...
- Retired_MemberAug 12, 2021
This sounds like a problem I had, Try this:
Go to into routeradmin pages go to advanced home and note the dns entries.
Go to windows control panel and click on ‘Network and sharing centre’
Click ‘change adaptor settings’. DoubleClick the ethernet/wifi adaptor and click properties,
highlight Internet protocol version 4(TCP/IPv4) click properties:
Click ‘use the following DNS server address’ and enter dns numbers in the ‘preferred dns server’ and alternative server boxes.
It seems that Netgear may have somehow screwed up the dns settings as well as removing the remote settings page.
Hope this helps
happysheep
Aug 20, 2021Aspirant
Also have this error, getting DNS_PROBE_POSSIBLE after the firmware upgrade. It will reload okay but this is annoying and can make some logins fail.
I had just gone back to the V6400v2 after putting it in the corner for having other issues on a previous firmware.
Changing the DNS to use Cloudfare is a good workaround but I am waiting for a solution from NetGear.
With WFH and school kids there are 5 laptop/computers and we each use 3-4 browsers! First world problem, I know.
Chemical4ce
Aug 22, 2021Aspirant
Hi Guys,
I am experiencing the same issue and it is very annoying especially working from home and using multiple SSO Logins forwarding pages and half of them constanlty failing.
is there any way to install an older FW? Is it offcially supported?
- robjakAug 22, 2021Luminary
- monkeywrench202Aug 30, 2021Star
I was having same issue I rolled back to version V1.0.4.66_10.1.75 from Deember 2020 you can download it from netgear and then install it to your router and then your problems will disapear mine did, good luck
- robjakAug 30, 2021Luminary
Rolling back firmware to a version with security flaws is not a fix. Switching to a new vendor is not a fix. Netgear needs to fix. Its not rocket science.
