philip_m
Aug 12, 2021Initiate
R8000 - Have to load every page 2x after installing V1.0.4.74_10.1.80
I updated my R8000/X6 to V1.0.4.74_10.1.80 yesterday. Now when i go to many websites (e.g this one) I first i get 'site not found' then i refresh the page (F5) and it loads. I tried firefox, Chrom...
- Retired_MemberAug 12, 2021
This sounds like a problem I had, Try this:
Go to into routeradmin pages go to advanced home and note the dns entries.
Go to windows control panel and click on ‘Network and sharing centre’
Click ‘change adaptor settings’. DoubleClick the ethernet/wifi adaptor and click properties,
highlight Internet protocol version 4(TCP/IPv4) click properties:
Click ‘use the following DNS server address’ and enter dns numbers in the ‘preferred dns server’ and alternative server boxes.
It seems that Netgear may have somehow screwed up the dns settings as well as removing the remote settings page.
Hope this helps
bkastel
Sep 17, 2021Guide
I noticed today that version 1.0.4.76_10.1.82 is available.
https://kb.netgear.com/000064035/R8000-Firmware-Version-1-0-4-76?language=en_US
monkeywrench202
Sep 17, 2021Star
just updated to new firmware ending in 82 and its seems like still same issue with DNS lots of websites coming back server not found ???????????????? same as firmware ending in 80 not sure what to do ? thinking about rolling back again ?
- FURRYe38Sep 18, 2021Guru - Experienced User
Try a full on factory reset on the router and setup from scratch before rolling back FW.
- monkeywrench202Sep 18, 2021Star
Ok, tried what you said did a factory reset started everything over which was a lot with 11 security cameras and just finished and still same problems lots of websites saying server not found will not connect on lots of websites , now have to roll back to version 75 and remove version 82, and 80 is also the same issue going back to 75 everything works fine , two hours of wasted time.
- robjakSep 18, 2021Luminary
Netgear did not update the 8300 FW. Netgear Engineering had stated that they had a fix for the DNS issue on the 8500/8300. I expect to them to call me to test it tomorrow.
There is no need to do any resets for the DNS issue. Total waste of time. If i had to do a reset and setup from scratch everytime I updated firmware, i would smash the NETGEAR with a hammer.
- Hopper15Sep 18, 2021Star
"If i had to do a reset and setup from scratch everytime I updated firmware, i would smash the NETGEAR with a hammer."
lol I'd be right along with you.
