davidmarli's avatar
davidmarli
R8000 - impossible to install
Hi,   I just pick up an old R8000 (certainly with old firmware (I installed it a few years ago, perhaps 6 years, in my office) I reset it, and wanted to setup it up at home. I want to use it as a...
  • davidmarli's avatar
    davidmarli
    Feb 24, 2025
    Hi,
    thankl you very much for all your answers.
    I managed to do a reset and managed to update the firmware.
    The way it worked : just wiring an ethernet cable between 1 of the 4 eth port and my laptop.
    I accessed the router with 192.168.1.1
    Now I can configure it.
    Once again thank you very much for all your help.
