davidmarli
Feb 21, 2025Aspirant
R8000 - impossible to install
Hi, I just pick up an old R8000 (certainly with old firmware (I installed it a few years ago, perhaps 6 years, in my office) I reset it, and wanted to setup it up at home. I want to use it as a...
- Feb 24, 2025
Hi,
thankl you very much for all your answers.
I managed to do a reset and managed to update the firmware.
The way it worked : just wiring an ethernet cable between 1 of the 4 eth port and my laptop.
I accessed the router with 192.168.1.1
Now I can configure it.
Once again thank you very much for all your help.
davidmarli
How do I log to r8000 ?
I can t...
When I try using it s ip adresse (192.168.1.123) it tells me files are missing....
Nighthawk app doesn t work...
I can t...
Feb 21, 2025Guru - Experienced User
Try a factory reset on the router and then walk thru the setup wizard.
Then follow the PDF to setup AP mode for the .80 IP address, after you apply that, you should be able to log into the AP mode configuration at 192.168.1.80.
What FW version is on the router?
- davidmarliFeb 21, 2025AspirantI ve already done that (reset factory)
It is impossible to reach the pages of the r8000 interface.
I don t know what s the version ofbthe formware, but it has never been updated since it was installed 6 years ago...- FURRYe38Feb 21, 2025Guru - Experienced User
After a factory reset you should be able to start the web page at 192.168.1.1.
- davidmarliFeb 21, 2025Aspirantok. So I must unplugged my Internet provider router first, while it has already this ip adress.
i ll make a try next week
