rmh77243
Nov 09, 2020Tutor
R8000 - Slow ethernet speed
There are multiple posts on the slow speed on this router but I did not find any that are similar to the issue I have. I have also tried most things listed apart from a factory reset as avoiding till...
itsmecantusee
Nov 23, 2020Star
Thanks,
I'm not sure how you construe my reponse to the R8000 slow ethernet speed post as "thread jumping". Is it not exactly what my issue was?
Nov 23, 2020Guru - Experienced User
If you're wanting help, the threads are supposed to be for each individual person. So we can tailor help and make sure not to confuse the original posters details with someone elses. Jumping in on another thread wanting advice is thread jumping. You can go through a thread and try things and post what works for you but if you're needing help, please start your own and we'll be happy to help.
