svanlith
Feb 19, 2016Aspirant
R8000 & Readycloud Registration failed
Hi Fora, I have recently updated my R8000 to firmware version V1.0.3.4_1.1.2 and figured I'd give the Readycloud a try. So I was able to logon online and even with the app, but as soon as I try ...
- Feb 01, 2017
Hi jeffm6719,
Try changing your password to a simpler password. For example: Password123
danntlewis
I also have the same issue. "Registration failed. Check your user name and password and try again".
ElaineM
Feb 22, 2016NETGEAR Employee Retired
Just want to check with you guys if you're still having problems.
Let us know if you're still having difficulty registering.
