fmiranda
Jun 16, 2016Aspirant
R8000 2.4Ghz connection really slow, 5GHz super fast
Hello, I have a R8000 fully updated 1.0.3.4_1.1.2. The 2.4Ghz band is running at 600Mbps (according to the advanced netgear menu). I noticed on my wifi device that it would not losd webpages fast,...
- Jun 19, 2016
Quick update, I got a Netgear 6400 (AC1750) for 120$ at Bestbuy, replaced the R8000 and all my devices on the 2.4Ghz WiFi are scoring best results than before and on my router GUI administration page it shows 450Mbps. The results are similar on the 5Ghz WiFi network.
Conclusion, the R8000 could be a great device, unfortunately is too buggy and the firmware is not stable enough.
If you don't have more then 12 people streaming at the same time in your 5Ghz, forget the triband routers, go for the dual band ones (AC1750 or AC1900), they are cheaper and most of the time offer the same speeds the standard WiFi devices support - plus the 2.4Ghz band works better and its more stable!
TheEther
Jun 17, 2016Guru
Yeah, 0.5 Mbps is pretty bad. Do you have anything that could be causing interference in the 2.4 GHz spectrum? Baby monitors, old cordless telephones, Bluetooth devices, satellite receivers or microwave ovens? Here's a good article by Apple.
fmiranda
Jun 19, 2016Aspirant
