tj66
Aug 14, 2015Tutor
R8000 55 Mbps vs 90 Mbps for direct connet
MY speetest results are routinely 90 Mbps when connected directly to the cable modem. When I connect the modem to the router, my ethernet sppeds drop to about 55Mbps. Any ideas?
- Aug 20, 2015
When connected to the R8000, what is the connection speed of the WAN port?
If you have QoS enabled on the router, disable and test again.
netwrks
Aug 15, 2015Master
I would start by swapping out the Ethernet cable between the router and modem. Try a CAT6 cable..
tj66
Aug 16, 2015Tutor
Thanks. I've been using the same CAT5e cable for both tests. I just switch it from the router to the modem. I don't happen to have any CAT6 cables. I'll try to dig one up.
