tj66
Aug 14, 2015Tutor
R8000 55 Mbps vs 90 Mbps for direct connet
MY speetest results are routinely 90 Mbps when connected directly to the cable modem. When I connect the modem to the router, my ethernet sppeds drop to about 55Mbps. Any ideas?
- Aug 20, 2015
When connected to the R8000, what is the connection speed of the WAN port?
If you have QoS enabled on the router, disable and test again.
tj66
Aug 20, 2015Tutor
I ran CAT6 from the modem to the router and from the router to the PC. No change in speed tests, still 55 from the R8000 and 90 from the modem.
netwrks
Aug 20, 2015Master
- tj66Aug 20, 2015Tutor
This worked fo me. In fact, I was able to disable QoS, run a new speed test to get the higher results and then renable QoS and keep the speed increase. I'm leaning toward leaving QoS off though as it seems like more trouble than it is worth....
Thanks!- netwrksAug 20, 2015Master
Happy to hear work getting your speeds. If you can keep it off, you should..
