Rockmeister64
Aug 03, 2022Aspirant
R8000 5G modem drops connection when large files are copied
Hi I have R8000 Triband router that has been working very well for years (except of the DNS issus for which I had to downgrade). I just bought a new Minisform UM560 which has a rz608 wifi 6e card (...
Aug 04, 2022Guru - Experienced User
Have you tried getting the RZ608 driver straight from mediatek?
Rockmeister64
Aug 08, 2022Aspirant
The issue seems to be the Netgear firmware. I upgraded to the latest V1.0.4.84_10.1.84 firmware and turned on IPV6 and set it to "6To4 Tunnel" for the DNS issue. However, the DNS issue remained unsolved. I tried reverting back to V1.0.4.68_10.1.75 the DNS issue was still there! Tried IPV6 to Disabled and still the issue remained. By now I was on thin ice with wife and kid!!! Between the unsolved DNS issue and the current issue, I was done with the Netgear firmware.
Did some quick research and chose OpenWrt as the firmware replacement. Used their wiki https://openwrt.org/toh/netgear/r8000 to install the router and https://openwrt.org/docs/guide-quick-start/basic_wifi to setup the Wifi.
No DNS issue (obviously) and the large file copy went through with out an issue.
To recap
Issue: The 5G radio stops working when copying large number of files with PC using rz608 wifi 6e card (rebranded MediaTek MT7921K).
Root Cause: Netgear Firmware (both V1.0.4.68_10.1.75 and the latest V1.0.4.84_10.1.84) has issue handing large file copy
Solution: Use OpoenWrt firmware
Hope this helps others.
Thanks
Rockmeister64
- FURRYe38Aug 10, 2022Guru - Experienced User
I put my R8000 FW v.84 online behind my CM1200 modem.
Connected a RAXE500 router wirelessly (wireless bridge) to the R8000 on a 5Ghz radio. Smart Connect disabled so I can ensure I'm connecting on a 5Ghz radio. 1300Mpbs connection rate seen on the RAXE500 connection status.
Wired PC connected to RAXE500 on 2.5Gb LAN port with 2.5Gb ethernet adapter on PC.
Sent a 4Gb file up to a drop box with no problems or disconnections being seen.
Sent a 32Gb file up to a drop box with no problems or disconnections being seen.
