Boubousse
Jun 26, 2017Tutor
R8000 and laserjet 1200
hi, May I connect my laserjet on my router r8000? i have plug it in usb on my r8000 but i can't see my printer. i want use my printer without power on my computer, with another device . ...
- Jun 26, 2017
Hi Boubousse,
Check this KB article.
https://kb.netgear.com/19593/ReadySHARE-printer-set-up-instructions
You have to install ReadyShare print utility for it to work.
JamesGL
Jun 26, 2017NETGEAR Employee Retired
Hi Boubousse,
- BoubousseJun 27, 2017Tutor
Hi,
Many thanks, i try it quickly.
Best regards
I tried, the printer is connected in USB on the router but the pc must be switched on so that I can see the printer on my iPad. But I want to print from my iPad without switching on the pc.
many thanks
best regards
- JamesGLJul 03, 2017NETGEAR Employee Retired
Hi Boubousse,
It is how it works since the computer is the bridge for the printer to work with your iPad.
