mui
Aug 03, 2022Aspirant
R8000 bricked
I have attempted tftp & nmrpflash numerous times but there were never any "flashing light" moment.. is the router certified gone? Thanks..
- Aug 09, 2022
sounds like its truly bricked. You could always try the serial port method of recovering it but I'm not sure how much more time/$ I'd invest in it.
Aug 03, 2022Guru - Experienced User
What are the lights on it doing? (all of them, color, blinking, etc)
what error are you getting when you tried tftp/nmrpflash?
Did you try a different power supply? (I've seen the wrong ones used and cause issues or ones going bad)
