mui
Aug 03, 2022Aspirant
R8000 bricked
I have attempted tftp & nmrpflash numerous times but there were never any "flashing light" moment.. is the router certified gone? Thanks..
- Aug 09, 2022
sounds like its truly bricked. You could always try the serial port method of recovering it but I'm not sure how much more time/$ I'd invest in it.
mui
Power: solid half red & half white
2.4ghz, 5ghz1, 5ghz2, USB3.0, USB2.0: solid white
and the rest are not on at all..
tftp had #0 block, and doesn't seem to be loading anything at all
nmrpflash had Error: Ethernet cable is unplugged, i have tried different cables but still the same..
I will try to find a different adaptor to try and let you know.
Aug 03, 2022Guru - Experienced User
what do you mean half red half white. Does it blink on/off those colors?
Is it red for a period of time and then switches to white?
Is the wifi broadcasting?
- muiAug 03, 2022Aspirant
Half side it is, left half is red and right half is white, and rock solid as soon as the power is connected, no blinking nor flashing.
And no the wifi is not broadcasting at all.
- plemansAug 03, 2022Guru - Experienced User
Did you check the power supply?
You might have one sitting around that matches. Just make sure you have the exact same voltage/polarity. You can have higher amperage but not less.
I don't have one, will go & buy one from the shops tomorrow when they open!
