teddy_c
May 23, 2021Aspirant
R8000 can only get full speed if I factory reset it, but it only lasts for few minutes.
My broadband plan is 1Gbps and I use R8000. I did a factory reset. Then I plugged in the ethernet cable and did Speed Test , at beginning I can get 950Mbps, but a few minutes later I can only get a...
May 23, 2021Guru - Experienced User
how are you speedtesting?
Using the built in app?
Using speedtest through the browser?
what device are you testing on?
What modem are you using?
teddy_c
- speedtest app and speedtest website, they all give the same speed around 300-400Mbps
- the built in speedtest also gives the same speed.
- Mac OS
- ISP provided ONU
- michaelkenwardMay 24, 2021Guru - Experienced User
- teddy_cMay 24, 2021Aspirant
Hi, thank you for your reply
I think the model of ONU doesn't matter since if I plug the cable directly from the ONU to my PC, I can get around 980Mbps.
That's an unwise assumption.
plemans asked for that information because it could be important. They want to eliminate possible reasons for the problems you see.
If you don't wont to tell people, fine. But you won't get very far.
Is there any way to solve this issue?
