CarlosJr's avatar
CarlosJr
R8000 cannot connect to www.idrive.com after firmware update.
My R8000 cannot connect to www.idrive.com after firmware (V1.0.4.66_10.1.75) update. I can connect if I bypass the router.   I have tried using a different DNS setting.   Thanks,
  • CarlosJr's avatar
    CarlosJr
    Jan 02, 2021
    Thanks for the reply.  I did a factory reset as you suggested and it did not help.  I changed the router's mac address in internet settings as I saw on another post.  I rebooted the router as well as the modem.  It is working now.  Thanks again for your help.
