luh's avatar
luh
R8000: Can't find the 2.4 Ghz band anymore
I have a Netgear Nighthawk x6-router, Model R8000. I am not able to find the 2.4 Ghz Band anymore (neither in my laptop nor my mobilphone), only the 5 Ghz band is visible. How can I solve this issu...
  • FURRYe38's avatar
    Mar 27, 2023
    Try a factory reset by pressing the reset button for 10 seconds then release. When the LEDs on top change, Pull the power adapter from the wall outlet for 30 seconds then plug back in. When the router is ready, log into 192.168.1.1 with a wired PC or laptop and walk thru the setup wizard.
    Is the 2.4Ghz LED on top lit White or Amber?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
