luh
Mar 27, 2023Aspirant
R8000: Can't find the 2.4 Ghz band anymore
I have a Netgear Nighthawk x6-router, Model R8000. I am not able to find the 2.4 Ghz Band anymore (neither in my laptop nor my mobilphone), only the 5 Ghz band is visible. How can I solve this issu...
- Mar 27, 2023
Try a factory reset by pressing the reset button for 10 seconds then release. When the LEDs on top change, Pull the power adapter from the wall outlet for 30 seconds then plug back in. When the router is ready, log into 192.168.1.1 with a wired PC or laptop and walk thru the setup wizard.
Is the 2.4Ghz LED on top lit White or Amber?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
luh
Mar 28, 2023Aspirant
After the Reset of the router the 2.4GHz band was visible again.
Thanks👍
Mar 28, 2023Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
